Schaublin 102 question
P504
Sep 17, 2023
Hi All
I have a Schaublin 102 W25.
Inside the headstock, there is a pin that locates the collets when you thread them in. This pin stops 25mm rod passing into the headstock when using a chuck, so with larger stock I have to cut relatively short pieces before I can put them in the chuck. It seems this pin is completely fixed, but thought it would be worth asking if there is some trick I am missing to remove it or pop it in to fit 25mm through.
Thanks in advance
Phoebe
