Schaublin 150 Belts
droren
Sep 6, 2020
Hi,
On Schaublin 150 belts are listed in the manual (attached page). There are 4 belts listed there, 3 of them at the spindle side (2 for the motor). I find it impossible to obtain the lower belt 32.5/13/990mm (Continental Veriflex FZ 30°). Moreover, there is a 5th belt, which is connecting the two motors on the tailstock side, which control the Rapid. I'm not sure if it is a part of the Automatic Threading Attachment on my machine. I measured it to be about 600mm (internal), width is 32mm and pitch is about 6mm - 100 teeth (it is also light in color and not the black rubber all the other belts are made of - see picture). Does anyone know:
1. Can I get a replacement belt for the motor (a more common close-size belt that will fit)?
2. What are the exact specifications and original sizes of the Rapid belt, and can it too be replaced with a more common product (maybe different teeth count)?
Thank Yoy
  • BELTS.pdf
marcsO
Mar 24, 2020
SURREY
If you are able to let me have the part numbers to all the belts I can check with Schaublin if they are available and at what cost (£).
Marc
droren
Sep 6, 2020
Thanks. The Rapid belt is not in the manual or in any of the attached drawings. I wrote to Schaublin and they replied that thay do not stock it but it's PowerGrip 390 L 075 (which I found easily on eBay).
