1yesca
- Jun 1, 2004
have done lots of 1917 / p14 even put ears back on one i made a fixture out of steel that has a v milled at each end to support a receiver mandrel with a handle on the under side of the mandrel put the set up in a surface grinder and as its going back and forth just move the handle a bit tell the back matches front just like a rem mod 30 and then there's the index / lighting hole back there to fill or not to fill if its there and them dam 3-1/2 % nickel rec. for the most part they drill ok but they can be a bit gummy but thank god for the 17's and 14's for with out them most of us would never be able to build are 375's and 416's
