I have a project rifle I would like to mount scout scope integral bases on. I really want the scope to be low and normally this requires custom bases rather than the various approaches that have been tried on stock rifles like the savage and Ruger, or even the Steyr. My thought is to partially machine the bases, then silver solder them to the barrel, then machine the dovetail for the rings. If it didn't work I could pop the bases off, and try again when I have my stuff together.
None of this particularly puzzles me, except getting the bases to be a perfect fit for the barrel at the point of contact. Most barrels are tapered, and some are convex tapered, at least where the rear base sits. Other than roughing it on the grinder by eye, then scraping it to a perfect fit, I can't think of a way to do it. I mean, sure, purpose cut reamers for every external barrel dimension in creation, but that is not going to work for me.
I am after this kind of look/function:
Is it possible to mill a flat for the rear ring, not sure I would want to do that on a 375.
Any ideas on how to do the install? There are a bunch of kludges and after-market bolt-ons that could be discussed, but in my case it has to be an "integral" solution. No I am not milling them in to a raw barrel blank, but short of that soldering is as integral as it gets. It isn't simply about getting a scope mounted, I want to know how to do this specific job.
