https://nomorerust.com/store/blog/history-and-science-behind-mastercoat-and-how-it-works-n1
Here is a link to PM Industries, Master series of coatings.
I still call it paint, but whatever.
I was farmilliar with POR15 origionally
and how it works, and how NOT to get it on your skin.
I figured out the "moisture cure" part, as in once you
open the can, it begins to harden.
All that said, POR15 is good stuff.
I was at the car show in Carlisle and I saw this PM Industries
stuff. About 10 bucks cheaper than POR15 so I bought a can.
I had a steel gas tank with some pin holes in it.
I used my standard phosphoric acid clean and etch procedure.
Did a final etch with white vinegar and dried the tank out.
In the tank I put some of the PM Industries Master Series SILVER
paint. Turned the tank every which way, and poured out the excess.
That was over 20 years ago. Tank is still perfect.
I know they don't market this stuff specifically for gas tank coating,
but it says it is gasoline proof. I can attest that it truely is.
I honestly think POR15 SILVER is the same stuff.
Like the exact same stuff. The paint company must just put a different
label on the cans. I have seen all kinds of gas tank sealers on the
market. From Kreem to Red Kote. Nothing dries harder and is more
bullet proof for gasoline than this silver moisture cured urethane paint.
It just happen that I have actual proof of success using the PM brand
product.
TIP- If you have a screw on gas cap, use a polyethlyne sandwitch bag
over the threads, then screw the cap on, trapping the sandwitch bag.
This seals off the area pervectly, all the way to the top of the tank threads.
--Doozer
