CarbideBob
- Jan 14, 2007
- Flushing/Flint, Michigan
Why okay in center and poopey near the outside?
My theory is that the ways are worn more in the middle and therefore looser. Reasonable?
I don't think that it matters how long the pump timer is on.
A Bijure unit will only fill a certain void in the metering stem (?) and once that is full - it's full.
Then it seemed that after the pressure cycled off, that the new volume of oil was shifted to the other side of the piston, and then was pushed out by the next pressure cycle.
So a shorter time between cycles would push more oil, but a longer pressure cycle should not change volume.
At least on Bijure.
If not, then the line with the most resistance (plugged?) wouldn't get any,and the most free flowing line would be flooded.
At least that is how it seemed to work when I was working on mine the other day, and also how it makes sense for the system.
I could be wrong, but I don't think so.
Think Snow Eh!
Ox
Sounds logical Ox.
But on my Siemens lathes they definately used a lot more oil after me changing it.
Looking in the back the slides were always nice and wet and the machines stayed as accurate as the day i bought them.
I looks like it was running fairly dry of oil?
