I believe the siemens and the lmc controller are both industrial....... Look idk everything and some have you have forgot more than I know but pretending like nothing under 6 figures is worth machining on is silly
Sent from my LM-V600 using Tapatalk
I was only edumakating TeachMe that Mach has advanced into #4.
Now, as for your plan....You need a plan. Business plan.
#1 What work will you do?
#2 Where will you get it?
#3 Where will you do it?
This then = what machine size/envelope you can have.
Because if the answer to #1 = small, you don't need a Cat50 2metre X travel 10 ton machine.
And #3 plays a big part, because what is factory access like (tight, low door etc), factory floor like (if thin then light machine only etc), have you 3 phase and how many amps incoming etc.
If you do a proper bus plan, it should generate a whole lot more questions.
The whole idea of all of this - is to make you think.
Lastly, if you like the size/footprint of a Syil, or perhaps even the colour, then you'd love more a used Robodrill.
Same footprint.
Different league.
And yellow.
