Sharpening a left hand drill bit
Bill D
Apr 1, 2004
Modesto, CA USA
I own a few left hand drill bits for drilling out screws and bolts. Can a inexpensive drill sharpener machine work with them? I have a black diamond machine. I have one bit that someone sharpened assuming it was a cw drill. the angles do not work. no relief.
I feel my hand sharpening will confuse my muscle memory.
Bill D
eKretz
Diamond; Mod Squad
Mar 27, 2005
Northwest Indiana, USA
Your Black Diamond can probably do it with the correct parts but those would be $$$. For an inexpensive way to do it, maybe one of those cheap swing grinders you can stick to the bench for grinding on the side of a bench grinder wheel might work? Dunno. I generally hand sharpen mine on the bench grinder wheel as I'm not worried about whether they drill exactly the right diameter. I use them rarely and for the same purpose as you do. They don't seem to mess up my muscle memory any for grinding right hand drills (I think that's what your meant?).
boslab
Jan 6, 2007
wales.uk
I hand grind, odd I find LH easier?, perhaps I’m a closet lefty? ( not that sort, the other one) I do use both hands a lot, ( not for that, other things like welding)
Mark
michiganbuck
Jun 28, 2012
Mt Clemens, Michigan 48035
One good way to sharpen for someone not having the skills for drill sharpening is to dress the bench grinder wheel very flat and shut down..., set the table of the grinder so as to get a 12* clearance. Draw a line or clamp a bar on the table to mimic 30*..Then with the tooth lip eyeball flat across the top, Just bump the tooth to the wheek straight in and make the two grinds come to very near center.. This will make a facet grind..then you roll the heal away with the conventional rilling the drill but not coming quite up the faceted grind.
One can do this same with a V block tilted at 12* and skim across with a surface grinder wheel, or bump a wheel side(re: the book says to not side wheel grind).
The facet grind works very well.. but the heal must be cleared or the heal will rub.
michiganbuck
Jun 28, 2012
snip off the ground prong and plug the sharpener in backward.
On that Method..one might not snip the prong for elictrivically safety...but bolt the grinder unit to the ceiling so everything is like a mirror..and then likely gooder enough to grind left-handed.
Turbowerks
Nov 9, 2018
Windom
I have a nice black diamond left hand sharpener. Bid on it on a online auction they had two sitting on a bench the auctioneer didn’t know one was left hand (or did i) asked me which one i wanted i said the one on the left … turns out it was a left handed grinder when i picked it up. That how i got one now if i only had left hand drills[emoji2957]
When I find it I don’t need it
When I need it I can’t find it!
Apr 19, 2006
Manchester, England
I’ve ground ordinary drills into a left hand cutting edge in the past. It works just as good as a left hand drill for removing broken screws etc. It takes a bit of thinking about though.
Regards Tyrone.
eKretz
Diamond; Mod Squad
Mar 27, 2005
Regards Tyrone.
Grind them with a little extra rake and clearance and they bite in and grab better too. Helps get those stuck fasteners out PDQ sometimes.
CarbideBob
Jan 14, 2007
Flushing/Flint, Michigan
For removing screws I take the back end of a carbide endmill and hand grind it into a left hand spade.
Works oh so great on broken toolholder screws and the endmill is still usable for its normal purpose.
Apr 19, 2006
Manchester, England
I remember getting 16 broken cap screws out a steel ring that way. The screw heads had all been burst off so I figured the screws weren’t actually in that tight, they were just sheared off flush with the top of the component and there was nothing to get hold of. I could have probably got them all out with a scriber eventually. The guy who gave me the job said “ When shall I come back for it ? “ I said “ Just wait there, I’ll only be a minute “.
You should have seen his face when every one came out really easy, zip, zip, zip. It only took me a couple of minutes to get them all out.
Regards Tyrone.
