eKretz
Diamond; Mod Squad
- Mar 27, 2005
- Northwest Indiana, USA
Good, if u find ‘em let me know!
Ok, finally found a few minutes and remembered at the same time. I have a box of 10 that I'm sure are the right ones and a bunch more with sightly different geometry that I think will work if you want them. The 10 are SNPE63G pos/neg with a 30° lead angle. Some sort of gray coating but I don't know what exactly it is. Grade says "518" not sure what brand they are because they've been reboxed due to original boxes deteriorating, but thinking probably VR Wesson. Those are on the left in the photos.
I also have some VR Wesson TiN coated grade 653 that are double positive, 15° lead angle that should still work fine but cut a little freer since they will have a bit less contact on the bottom edge without the wiper flat, 39 pcs. - on the right in the photos. Also have Carboloy 395s uncoated, same geometry as 653s, 40 pcs. not depicted, look just like the 653s but no coating.
I'll give 'em to you cheap or you can offer me something interesting in trade.
