52 Ford
- May 20, 2021
What type of first aid supplies do you keep in the shop?
I partially lopped off the end of my left pinkie finger with a shear a couple hours ago. I'm fine, just a flesh wound. I was cutting some steel with a pair of snips and the end of my pinkie was between the handles on the shears.... ow.
I keep a lot of first aid type of stuff in my truck. Probably not enough, but I don't have a medical background or the training for the "serious" stuff. I do plan on taking some classes on trauma care or whatever they call it.
Anyway - like I headed this post with - what do YOU keep in the shop?
I'll be completely honest. I keep tape and paper towels.... no first aid kit. I'm close enough to my house that if I have an "oh shit" moment, I just go to the house and take care of it there. Heck, if it's something bad enough that I couldnt make it to the house, I'd probably be checking out, anyway.
The most important thing I can think of that not a lot of people keep in the shop (me included!) is a tourniquet (also hard to spell).
I keep super glue and string in my first aid kit, too.
Pay attention to this part: Super glue and string. Once you get the bleeding to stop, you can cut a series of short (1 inch, 25mm) long bits of string, run a bead of glue on one side of a cut, stick the string in the glue spaced apart maybe 1/16" to 1/8" (1.5 - 3mm), then run a bead of glue on the other side of the cut. Pull the string tight and lay it in the super glue (at the same time, of course).
I've had some really bad cuts that would warrant stitches, and I was able to close them up with that method.
Oh - another one... I keep bandaids and a zip lock with Aspirin in my wallet. I also keep Aspirin in my truck. Better to have it and not need it than to need it and not have it.
I write the date and the TOTAL milligram amount on it. I figure, if it's in my wallet the pills get crushed up... milligram per pill doesn't mean anything then, just approximate an appropriate dosage. If someone is having a heart attack, I don't think they'll mind.
I keep a couple paper towels and a few feet of small dia steel wire (flourist wire?) in my wallet, too. The paper towels end up loosing their "fluff" and don't really add noticeable bulk to my wallet. The wire is thin enough, its like adding a dollar bill or two in thickness.
Not only are they paper towels and wire good for cuts (heck, you could stitch up a cut with the wire), it's good if you really "gotta go" and you need some paper... it has come in handy for the latter use more than once when I was in the woods!
I'm not "prepper" or whatever. I just don't like the idea of not being able to help someone.
OH! Buy some quick-clot, too! It's a powder that you put on a cut to coagulate the blood. Stops bleeding. It's good stuff. The only thing you have to keep in mind is that if you have a nasty cut that needs stitches and use use quick-clot. It has to be cleaned out of the wound before they can stitch it up. Not a huge deal, but it's worth noting.
Celox is the "big name" for quick-clot, that I'm aware of. My old neighbor was a nurse and an MMA fighter. He used Celox. When I was a kid I split my eyebrow pretty bad and he uses Celox. Bleed-Stop is another brand; that's what's in my truck.
Sent from that other place, no not that one, the OTHER other place using Tapatalk.
