The points others make about the effort to come up with a bar that meets your spec are spot on. You could make a bar that has the ksi strength, and the physical dimensions, but it might fail in practice.
Annealed steel is softer than heat-treated, and has lower ultimate and yield strength. When you heat treat a product to increase hardness or strength (they generally a both increased when you do a standard HT) you can end up with a very strong, very hard part. But the part is also brittle. This means that when the bar approaches its yield point, it doesn't bend, it breaks. Shatters, actually. It has no toughness. Yielding parts with really sharp edges, potentially propelled at high velocity. So heat treatment usually includes a tempering process. The steel is heated up (to a temperature less than that used in hardening it), "Soaked" for a while, then quenched again. This lowers the ultimate and yield strength, but most importantly makes the part less brittle. As in tolerant of bending without breaking.
Different steels need different HT processes, and the process for a given steel can be tailored to optimize strength vs toughness. Your competitor, Rogue, shows the "Ohio Bar" that uses a 190ksi steel and is made using a CNC process (look at the website under Ohio Bar, and you'll see a Haas CNC machine that they purport to use).
The problem is that these bars are not very sophisticated in basic design (the bushings and such are pretty simple), and you are competing against guys with massive volume (e.g. Rogue). My son is a Level 1 Crossfit trainer, and I just shake my head at the volume of Rogue stuff he's bought. Since the basics are easy, it's the important details (steel selection, cost, HT, machining process, capital investment in tools, programmer skill, operator skill) that matter on price. And you have firms that have sold thousands of these bars and have those details fine-tuned.
If you were a machine-shop/engineering genius, you might have some insight that let you come up with a lower-cost, higher-quality product. Maybe you'd figure out how to make a better product with cheaper steel or something. Otherwise, I think you may be in the "I want to market my own brand of cola drink. It has to have X% of sugar, be brown, and have a cola taste that matches or beats Coke. And I want to manufacture it for about half of what Coke costs to make". I hope I'm being realistic and not too negative. I do wish you luck.
Folks asked about what an Olympic bar is. Pic below.
