Pete Deal
- Apr 10, 2007
- Morgantown, WV
I have been working on getting my 4th axis setup on my Brother S1000. An issue I have is that my Haimer is a little too long. My whole 4th axis setup (Brother T200 rotary) is pretty high.
My Haimer probe is in a 3/4" endmill holder with about 2-1/4" gage length. This makes the whole assembly pretty long. I was looking around to see if there are any shorter 3/4" endmill holders for Bt30. Maritool has one that's 2" but that seems as short as I can find. I think the 3/4" BT30 holders are longer to avoid deforming the taper. I thought Haimer had probes with integral taper shanks but that doesn't seem to be the case. Thinking maybe cut the endmill holder off by an inch or so and locktite the probe in? I started to face the tool holder off but that'll be a project. Not sure how hard it is but I need to get a few more inserts to get it cut down this way. Can't remember the brand. Looks like Haimer makes a probe with a 12mm shank. But I don't see any short 12mm endmill holders either.
Anybody got any ideas?
Another thing working against me is that on the S1000 the rotary needs to set on an adapter plate. I'm thinking at some point I may drill and tap holes in the table to eliminate the adapter plate to help this situation. This will lower the 4th by 3/4". Not going to rush into this.
