300sniper
- Nov 14, 2006
- Greenwood, Ca
I think he was giving you a hard time about combining a dimentional measurement with an anglular measurement.... ;-)
Under 4000 rounds I would normally expect rifling to still be in decent shape- but you say it doesn't look that way.
Set-back and re-chamber is sometimes done, but I'm not as quick to say "go for it" just because it's a "free" barrel. Isn't your time, worth $$? You'll be kicking yourself if you spend hours on the work- more than you'd spend on threading and chambering a new barrel- only to find out that the bore/rifling is worn to the point that it wan't a feasible project from the beginning.
If it were sent to me, I'd use a gage pin in the bore to determine if it's still .300- or if it's worn. If that shows excessive wear, I'd slug the barrel and mic it to determine the groove diameter as well. No point in all that work if it's now a .309-.310 groove barrel instead of .308. Like I said, unlikely- but that's based on your observation.
Thanks for the replies folks,
It is a free barrel, I don't have a borescope. The barrel is about 30" long so I could cut about an inch and a half off the breech and 1/2" off the muzzle and recrown it and still have about 28" of pipe left.I'll only be using it to pop whitetails from the bench in my stand, so I think I'll give it a try and see what I end up with. I've never chambered a barrel before so it will be good practice,which was the original idea but I had hoped to end up with a decent shooting deer rifle when finished.
I think that is very doable and good practice, I have re-purposed several of my old match barrels to be hunting rifles for friends, cost me nothing but a little time. I will suggest that you take off as much of the chamber and muzzle end end as you can and end up at 24" to a max of 26" for an '06, the rest is just extra weight. (Most factory magnums are 26") There is a lot to
be said for short and stiff barrels accuracy potential.
It's his first time chamberibg a barrel so the time wouldn't really be wasted anymore than if it attempted it on a piece of bar stock. The value of cutting a first chamber is worth more than time, in my opinion.
+1 Nearly ALL my deer hunting was in Western PA and WBGVA. We'd zero for 150 yds, expect to take shots at 5 to 100 yds, NEVER take a shot over 200, so jest hold dead-on without worrying about range and it was more than close enuf (8 mm Mauser - several, 7 mm Rem. Mag, .300 Savage, all with Balvar 8's dialed to about 2.5X)
That's just the way the woods and lay of the land be out that way.
Still basic .30 Win / .32 Rem iron-sights meat-getter country, not like Texas or Arizona atall.
Bill
True but Col. Whelen's Quote "only accurate rifles are interesting" still applies.
Thanks for the encouragement Paperpuncher, I didn't mention that I don't want to end up with an '06 though,planning to thread this barrel onto a 700 Rem action that I blueprinted a couple of years ago. It was of an '06 but I'm either going with an Ackley improved '06 or a .300 Win., thats why I brought the old Rem. .270 to .300 Win Mag. thread back up. Leaning toward an M16 style extractor and the .300.
For what it's worth, I would use a 1° leade and only enough freebore to allow seating the heaviest bullet I would use at the seating depth I want. It is best to engage the rifling as soon as possible.
You need a bore scope to really see how torched and the depth of the throat erosion. I have a 6.5x47L rifle with 4,747 rounds fired through it, even though the erosion is close to 3" long the barrel still will hold less then a 3/8" MOA on average. Even setting back my barrel a inch would never give me a good throat. You have to determine what your accuracy needs are before doing anything to your rifle.
I repurposed a used .222 barrel that had ~12k rds thru it for a service rifle barrel. Cut 5" off the breech end and still had to chamber it before the cracking was gone. And that also cleaned up the land that was missing from cleaning rod wear. Currently have another 3500 rds thru it and it seems to be doing just fine.
Notice
