Hi, everyone, have a question about shrink fit process...
Here are basic dimension At room temperature:
Shaft: 42.189 - 42.2 mm
Gear bore: 42.139 - 42.15 mm
Gear outer diameter: ~ 64 mm
Gear height: 75 mm
currently, we cool the shaft to -40C, and heat up the gear to 150C
cooling and heating are done approximately at the same time, (we just let the gear keep being baked in induction coil and wait till cooling temperature reaches the set -40C)
After that, a small robot arm grabs the gear and put onto shaft.
The process works but we have 20% of failure rate, mainly happen when the gear is stuck on the shaft just a couple of millmeter away from the final installation position when the robot arm is guiding the gear down.
I am no expert in heating/cooling process but what could be the causes? is the speed of dropping the gear onto shaft too slow? Some people mentioned that the shrink fit process needs to be speed of light? is the heat transfer from the gear to shaft really fast to a point that the gear bore size starts to shrink fast during the installation process?
Thank you
Gear height: 75 mm
Thank you
