We have old Hauser jig grinder which isnt in working condition and guy which run it got better job. So we dont have jig grinder which isn't problem until it is needed rarely but when is needed it is big problem not having it.
One option which is proposed is we get new air turbine for HASS VM2 and do grinding of small holes. Air turbine isnt cheap at all and I have feeling it would be problematic on its own.
We use sinker EDM also from time to time but for it there is more work then for jig grinder and our sinker is also old and guy which run it isn't younger either.
So I was thinking if new or second hand cnc sinker EDM could be used to replace jig grinder, we will get lot newer sinker which is lot easier to run then old one which can fail any moment. CNC sinker EDM which can replace jig grinder would be big argument to get one, because they are reluctant because old one is still working and second hand non cnc sinker EDM are cheap.
But because grinding isnt my field I don't have clue what is better option to replace jig grinder so any thoughts from you grinders?
Btw we dont work some massive molds so even smaller cnc sinkers will do the job.
