implmex
- Jun 23, 2002
- Vancouver BC Canada
The title kind of says it all; I'm sinker EDM matching a super complex parting line on a mold, with five tapered shutoffs.
I burned it as close as I dared to go and now I'm burning the hotside core against the coldside core to match the corner rads and bring the parting line together the last 0.010" (these are side shutoffs, so I'm only actually removing about 0.001" of material to close the mold by 0.010")
Problem is, I have no generator settings for steel on steel burning, so the burn is going slow as molasses on a cold day.
I'm running a Hansvedt MS4 Foreman sinker.
I have been playing around by trial and error, trying to find better settings than what I have been using; (I started from my settings for copper tungsten against steel, and I'm putting 4 amps into a burn whose surface area is about .0625 square inches. (1/4 x 1/4")
I'm unconcerned about wear of the half that's the "electrode" for this burn; it matters much more that they match, than that they be a specific shape.
Can any of you provide some guidance on good pulse duration, on-time/off-time ratios and anything else you can think of to give me a better starting point than simply guessing at it?
I am assuming, I don't want a "no wear" setting; it seems kind of pointless to be eroding the workpiece half while plating onto the electrode half, but other than that, I have no theoretical basis to help me find a good starting point, or what parameters to adjust from there to optimize the burn.
Cheers
Marcus
Implant Mechanix – Design & Innovation - home
Vancouver Wire EDM -- Wire EDM Machining
Cheers
Marcus
