PanarchyMills
- Oct 27, 2022
I'm setting up a nice clean Mori MS850, but there is a problem where it takes longer than it should to spool up to speed. For example 500 rpms takes about 5 seconds to get to speed, 1000 rpms takes a good 12 seconds to ramp up. My friend has the exact same machine and his is very snappy. Not a huge deal, but I'd like to get it resolved.
The problem existed when I bought it, so I can rule out my phase converter or supply side or any changes during transport.
Things I've done:
Complete drain and refill of the oil in the headstock (Mobil DTE Light)
3 new drive belts
Spun the motor without the belts to make sure the brake wasn't binding it, nope...
In-line current of each phase at idle is roughly the same amps
Resistance between each phase is the same (~3.3 ohms)
No shorts to ground
Spindle is nice and tight and spins freely in neutral. Still not super snappy starting in neutral. Gears in headstock all looked great when I had it opened up.
I've sourced a replacement motor for about $500, but if the current motor specs out with resistance, amperage, and no shorts, I can't figure out why it's weak and would need to be replaced. But there isn't anywhere else I can point to that would make it spin up slowly other than the motor.
The only thing I haven't done is pulled the motor and looked at the windings or cleaned it out.
Thoughts?
Things I've done:
3 new drive belts
No shorts to ground
Thoughts?
