BuiltByBen
- Nov 26, 2023
Hello everyone. I run a small specialty automotive repair, performance and fabrication business out of my detached garage. While it well set up for what I do, my biggest issue is dust! Apologies if this is posted in the wrong area, I’m new here.
I have scoured the web for info including this forum but maybe someone more experienced can help me understand the differences? Seems all the info I find is for wood working shops and unsure how much crosses with fabrication. I know metal dust can be combustible and requires some extra precautions.
Most of my dust will be metal from grinding and sanding, but I also heat my shop with a wood stove which adds quite a bit of dust. I’ve noticed everything covered in the shop and I clean very regularly.
There are old ducts from an air handler the landlord used for AC that have been removed, I’ll post a picture later. Wondering if I can filter through this handler? Initially I was looked into ceiling mounted HEPA units like Grizzly but there’s really no distinction between ones made for metal dust and wood dust. Maybe my brain is mixing dust collection and air purification?
Then I looked in to dust collectors which seem to be specifically to remove dust from a particular machine with ducting. Would I benefit from having both, a general dust purification for air and a dust collector for tools?
Looked in to HEPA air scrubbers which would be a good portable solution but do they need to be ducted? Not sure if these are designated for what I’m trying to do.
Then I had looked at converting a grizzly woodworking downdraft table in to a metal grinding downdraft booth (see
for part 1).
I’d like to work in a healthy environment, but with a lot of wood stove and fab dust in a closed garage in the winter with no windows or ventilation, I NEED to figure out how to effectively remove dust from my shop without running up a $1000 electrical bill or buying useless equipment.
Is there anyone in a similar boat that has successfully come up with a working solution? Maybe I need a combination of these units? There’s not really a local company that specializes in this that I can call. I appreciate any and all help/recommendations!
