sodium nitrite test?
henrya
Jun 25, 2008
TN
Absent a better answer, wipe it with ammonia and see what happens. As far as I know the nitrite test works. What is your question behind the question?
Lanso
Mar 16, 2013
Cerritos, CA
My question is - to anyone who has preformed this test - How accurate have you found the results to be?
I was about to buy some sodium nitrite and see for myself but first I thought posting this question here, I might receive a little insight into the subject.
scsmith42
Jul 28, 2020
New Hill, NC
Has anyone had success identifying white oak with the sodium nitrite test?
Yes, I do it when I can't otherwise identify it.
Red oak will still change color; but it will be a lighter brown than white oak. After 15 minutes or so, a drop of sodium nitrite on white oak will turn a dark chocolate brown. Red oak will be a lighter, greenish color.
What I usually do though is to look at the length of the medullary rays in a flat sawn board. In red oak, the rays will not be longer than 3/4". White oak, on the other hand, can go up to 1.5- 2" of length.
The open pore test is not always accurate, because chestnut white oak is open pored.
What is it that you're trying to identify?
henrya
Jun 25, 2008
TN
It gets tough when you have lots of white oak type trees around. I have some white oak, pin oak, post oak and chestnut oaks on my property and some sawn. They look similar but on side by side comparison they look different.
Here is an article from Missouri - apparently they have lots of white oak group trees too.
If you’re dealing with California grown wood, check to see what grows there for a start.
I will assume that you are mostly concerned with appearance as used in furniture. If so, you kind of need to go see the pile of wood and have a good hard look at it. If it looks like what you need it probably is. Quercus alba is the classic white oak for furniture making.
And more:
Lanso
Mar 16, 2013
Cerritos, CA
Thanks for your response - finally someone answered my question!
I have red and white oak in my shop that I do my best to keep separate and mark. I know all the methods to try to identify but it isn’t always that easy so when I heard of this chemical test I thought I’d try it.
Lanso
Mar 16, 2013
Cerritos, CA
I finally tried the sodium nitrite test and it does work. So far I’ve only tested known red or white oak and every time white turns dark and red will dry with just a little stain.
