I would loupe /eyeball each drill, which would only take a few seconds each and might turn up some bad grinds.
Look for clearance up to the cutting edge...and ballpark clearance..point looks on center, and the chisel angle is correct.
There is a good chance the points are circle-ground or just pressed that way to the angle, and then the clearance or heal is brought up to the edge to sharp..if the back-off does not come fully to the edge they are likely to break.
