South Bend 9 model A or Clausing 100 12"?
Fastbackperry
Mar 15, 2019
Thank you to all that share answers to my questions.
Several years ago I purchased a Clausing 12" I think a model 100 that doesn't have a quick change gear box. It was not beat and in good condition. I went through it cleaning and lubing as needed. The cross feed bevel gears were damages so it doesn't cross feed but other than that I've found it very handy. Recently I found a nice South Bend 9 model A (has gearbox)with a 4' bed in very good condition. Next to no wear on bed and all gears show no wear, are square, and no missing teeth. A nice new Dayton motor as well that I'll be wiring with a new reversing switch. The only thing I can find that it needs is the cross feed nut. So which should I keep? The larger Clausing in good shape is larger but doesn't have a gear box and needs cross feed gears or smaller South Bend 9A as just described.
Also, where is the best place to buy the cross feed nut? I do have a new felt kit for the SB so as needed those can be changed. Any other suggestions of things that should be checked and changed are appreciated.
Thank you so much!
Perry
