I just bought a FR-D720S-042-NA Mitsubishi VFD from Ebay. It was sold as new and it looks and feels like new. However there are a couple of "Sample" labels attached to it and a "Special 4136" label at the front. It was manufactured in February 2017.
When powered, it does not look and perform like a regular VFD. Many parameters are missing, there are some extra ones, the default values are different from the manual. The base frequency parameter P3 does not exist and I cannot set the maximum frequency P1 above 206 Hz. The 1/3 HP motor, connected to the drive, runs, but the highest frequency on the display is 70 and the Hz LED is not lit. In reality the VFD max frequency going to the motor is about 40 Hz, I checked the motor RPM with a tachometer. There is nothing wrong with the motor, I checked it with another VFD. So I can run very low motor RPM with this VFD, but I cannot run fast.
How can it be? Is it the result of a special firmware? Why would somebody make a special VFD like that? I also noticed the same seller sold similar VFDs before and has one more for sale right now. They all carry a "Special" label, but each one has a different number. The seller claims to have no knowledge about this and offered me a full refund. I called the Mitsubishi technical support, but they do not know anything about it.
