I just purchased a bridgeport series 1 2j mill and am still learning everything about the machine. I plan to take the machine completely apart and replace parts the parts that show significant wear and tear. I figure this will give me a better understanding of the machine as well as ensure that it will be running properly. My first problem is regarding the spindle. The spindle length is correct (roughly 545mm ), my drawbar length is correct (roughly 18.25 inches with the proper thread length).
Here's my issue: the drawbar will not reach to be able to thread onto a collet. I am attempting to us r8 collet but they will not fit into the spindle. Roughly needing a little over an inch more space.
My guess is that I have a piece of a collet that someone snapped off inside the spindle and now has been lodged in there. I added some pictures for reference. If I am correct, someone already bored out the piece because the drawbar no longer threads into it. My only thought is to tap it and use a separate threaded bolt to get it out.
Let me know if this sounds correct or I'm completely wrong. Thank you
