Wren
- Jul 12, 2007
- Tuscaloosa, AL
We are having a problem with our machine that I hoped to get some help from the people here on.
The machine is a Hurco VMX 24 with 10,000 rpm 40 taper spindle. Spindle hp is listed as 10/12.5.
The problem we are having is that the spindle acts like it does not have enough hp available as it should. Turning on a 1/2" endmill to 10,000 rpm takes 30-45 seconds just to spin up and another 30-45 seconds to spin down with the spindle load meter showing "overload" the entire time. This seems like an unreasonable length of time based on my experience with other machines.
When the machine is cutting it does not seem to have enough horsepower available either. For a standard pocketing operation, using a quality 3 flute aluminum end mill in 6061, I can only go about .200" deep and 25 ipm and the machine is screaming the whole time. I can even hear the spindle bog down with big radial engagements of the tool.
Also, the chip auger will trip its breaker soon after being turned on if there are many chips to push at all.
I have talked with Hurco several times and all of the spindle acceleration and deceleration parameters are correct. They think that the machine sounds like it is starved for power and I think so too but I cannot find it.
The power into the machine at L1-L2, L2-L3, and L1-L3 is always 235V-240V. We have run the machine on the three phase power that comes into the shop as well as on a Phase Perfect digital phase converter. The results are always the same. Electricians have come in and set up monitors to watch the power over several days and not found any problems.
Does anyone have any ideas or has anyone seen anything similar to this? I am at a loss and getting ready to call in the service guys.
Thank you.
Thank you.
