wood2steel
- May 17, 2013
- georgia
These Import folks screwed with everything else We Americans Engineered, so this will fit right in to this mix!!
The 3 Lodge and Shipley's here rule the Roost
A beer is common sense if no internal changes are made.For what?! The factory already confirmed that the machine is wired and operating correctly. Common sense dictates that the machine can be rewired for personal preference.
What I really want is an app for my cell phone so all I need to do to turn on the lathe is log on to my Apple account, enter my 26 digit password that contains at least 1 punctuation mark, one capital letter, and must contain 3 non-numerical characters then watch 2 one minute advertisements then select the proper menu, scroll down to the 7th submenu, choose the Universal Language symbol that represents 'ON', tapp it twice and then select Forward by holding my fingertip on the .2MM button for at least 3 seconds. Why can't they make it that easy?
My Victor 1660B is down for forward.I have a Clausing 5914 in my personal shop, which is mechanical clutch operating as Up-Forward, and I purchased a Victor 1440 lathe for the company shop a couple of years ago which also has the Up-Forward, Down-Reverse configuration. The other candidate for that purchase was a Sharp 1440, interestingly.
I think most older manual lathes were down for engaging the clutch. It's those newfangled electric switch jobbies that switched it up.
When I reach down and grab those L & S handles and pull up I can feel those beast come alive!!
A very fine machine you have there! Not sure i ever saw that Hydro-- version of Monarch out there!! I would have to believe there is some form of adjustment to close that distance on the lever travel for braking! Had my eyes on a Model 61yrs ago; sure hate that one slipped through my fingers. Lever action on that machine was the same; down for forward, up for brakingWell, my old lathe can complicate things a bit. It's 1962 Monarch Series 62 Preselector Dyna-Shift. Down on the lever is engage clutch/run. Up on the lever is brake/shift. If you want to change directions you have to brake to a stop then click a button to change to a different direction. If you look at the photo the right row of buttons is from top Red/forward, Black/reverse, Red/stop. To be honest if I had to stop it quickly it would take some thought. Granted just pulling the lever up makes it brake and it stops pretty fast considering the amount of mass inside that headstock. The bull gear is like 2" thick and 16" in diameter. The downside is you have to move that lever all the way up, and it's throw is like 12". If something was going wrong I am not sure I could move it that entire distance with any speed. It is not a little flick, it must go vertical. And neutral is full stop then pull out that little plunger in the middle of the RPM selector. Fully. It's all hydraulic so there is squish in the feel.
I wonder if it came from where I used to work ? In Mill Valley ? Looks exactly the same, even the name tag wear and, as you said, pretty rare model. Same geographical area, so could be ?A very fine machine you have there! Not sure i ever saw that Hydro-- version of Monarch
Notice
