SSD for a Fusion 640t
Madmaxx57
Jul 15, 2020
I"m trying to change to a ssd in my Qt250 Fusion. I have a formatted a 2Gb ssd. I formatted it in fat16. I cant get the bios to see it. I have changed the bios to auto detect and still nothing. I tried to put in user parameters but the cylinders stop at 1024. I'm thinking of partitioning the ssd to the 1024mb and see what happens. After I get the bios to read it..then I will be onto the cloning procedure. The current drive is a 2.1gb hdd. Machine is working fine and bios sees this drive properly.. I did a search but didnt get any specifics on the bios ?Any ideas? Any help is appreciated. Thanks!
Madmaxx57
Jul 15, 2020
I got it off ebay. SiliconDrive is the name. It has the IDE adapter attached to it. I just tried to partition the drive smaller 528mb as that size drive is in the bios..no luck. I'm unable to set the drive to C. I currently have it set to B. But I would think the bios would see it regardless?I'm thinking about what it was telling me, it says non system disc...I will try to boot from floppy now and see? thanks for the reply!
hanermo
Sep 28, 2009
barcelona, spain
IT stuff and SSDs with machine tools
With very high probability your problem is related to drive file formats,
especifically drive type descriptors in the boot sector loader.
Back in the day removable drives had specific codes and max sizes and boot descriptors.
Std windows tools cannot see or change them, some very few specialist windowz sw can.
Freeware linux based utilities will fix this in 5 minutes.
You download the linux utility onto a usb memory stick, then boot from the usb, and with a simple text/graphical interface you assign the file format on the ssd to something friendly, and make the ssb boot loader say bootable with a suitable partition system and bootloader.
Offhand I don´t remember the name of the linux utility I last used.
With complex cf/solid state drives on hp mini desktops.
Just change the drive type descriptor, then make the partition bootable and active, voila.
Very long story how and why and what drive systems / boot sector loaders / etc.
Mostly-all custom systems will boot from anything as long as the bios thinks it sees it and the MBR master boot record is in sync with the filetype-descriptor on the hard drive hw.
If you need real-time help, I can do that, via zoom etc.
Pm to agree.
I would expect normal rates for work, but with zero down and no-cure no-pay.
It would probably take 2-3 hours to solve, if it is the typical complex maze that these things were when I did this daily.
I´m happy to guide for free.
hanermo
Sep 28, 2009
barcelona, spain
SSD howto
Copy the original hdd to an image file.
Binary image.
If the original is non-windows, use another pc to copy the drive contents into an image file.
Then make a bootable ssd with suitable mrb, and bootable/active partition.
Then copy the image file to the ssd.
The machine will then boot from the ssd, while thinking it uses the original hdd.
The ssd must be the first/primary hard drive, or only hard drive.
Madmaxx57
Jul 15, 2020
Binary image.
we will give this a try. Is there a go-to copying/cloning software that works best? In a perfect work we would have a few backup drives ready to go and a copy or image on our shop pc, that we could download to a given hard drive. Plug it in and make chips!. many thanks for the responses!
Madmaxx57
Jul 15, 2020
This is where I am with this.
I bought an identical hdd as my original hdd. Formatted it with fat16. We copied the original hdd as an image file. Then copied it to the identical drive. The bios will not see the new drive(no slave/master jumpers). we can see the files on another pc but it will not boot or see it on mazak. Then We took a 4gb ssd and formatted it the same size as our old drive again fat 16. copied the image to it. Bios sees it but not correct size. It starts to boot then give memory errors saying himem.sys and emm386 driver arent there? They are there. Sometimes it will boot to a window screen but says we have a registry error. screen says to restore from backup. but we cant get move the cursor to click that box to do it. At that time there arent any keyboard or control key functions working? Am i missing something obvious here. any thanks for the replies!
ss_user
Jun 2, 2013
WA USA
Easy way to clone a disk is the linux utility dd. You can boot into a 'live' install disk for linux and run without installing.
Short form : dd if=source of=target
Hit up google for more dd options You may have to su ... to be superuser to make it work. :-)
dd makes an exact copy, and should cleanly boot afterwards. YMMV Good luck.
derekprad
Apr 13, 2022
Fusion Drive vs. SSD is a common confusion for those who want an iMac. When you buy a Mac device, you don't have a lot of customization options, except for storage. For example, if you buy a MacBook Air, you can choose the 128GB or 256GB version. However, you will have better choices when moving to an iMac. However, all my files were locked up when I had a problem. I had to go to salvagedata.com for help.
BOB-OO
Dec 5, 2010
NE PA
I tried and gave up, same issue cloning the 640 w95 drive. In the end my system had a motherboard error so we had to do the Mitsu W2000 upgrade which gave us the SSD & W2000 OS. ($9k)
I've heard of successful clone drives but never been able to do it, always the same issues you specified. I tried a bunch- Linux image, acronis, the clones would boot on test W95 machines but not on the Mazak, better protection then I could crack. If you figure it out I'd love to know since they beat me.
GBC Micros
Feb 13, 2019
Mazak SSD
What kind of SSD do you use?
I have successfully used a 8GB Compact flash with IDE adapter. (Windows 95)
can you if posable send me name and links to compact flash and ide adapter you used as i have tryed six types and cant get the bios to see any drive
