Stark Lathe/Mill Ser. 351
MrStretch
Mar 20, 2017
Here's something as magnificent as it is rare - the indexing head for the milling attachment.
The base:
The housing after cleaning and repaint:
The housing rotates on the pin in the base and is locked by the 2 threaded handles from 0 - 90 degrees
MrStretch
Mar 20, 2017
Next, the spindle, spindle lock and spring-loaded indexing finger
The spindle takes the same 4S collets as the headstock and uses a short drawbar the a hex cut on the end. The hex is not any standard fractional or metric size - 1.41" or 35.86mm
The spindle is constructed just like the headstock spindle. The outer race of the back bearing slides on a keyway and is a tight slip fit on the spindle. The threaded ring is used to adjust and secure the bearings. I used a close fitting punch in the unthreaded hole in the adjuster and tightened the bearings by holding the front of the spindle between soft jaws on my bench vise and then tapping the bottom of the housing flange with a mallet.
lock.jpgThe parts for the spindle lock and indexing finger. The spindle lock is a simple spring loaded plunger that fits into one of the four holes in the center of the spindle. The index has a hold-off whose tip drops into the slot at the rear of the housing when the index is pulled back far enough from the indexing gear. Simple and elegant.
MrStretch
Mar 20, 2017
Here's a few pictures of the lathe in the afternoon light. I moved it to the front of my little rowhouse in anticipation of moving and setting up my clock workshop in the front room.
