Starrett 120-A calipers - crystal re-installation
specfab
Active member
I looked for this topic and haven't found anything of specific use yet...
I have a Starrett 120-A 6" dial caliper, made around 2005 0r 2006, which has the dial crystal popped out. I was gently trying to clean the rack and pinion with a little Dust-Off to get a chip out, and the pressurization under the dial assembly just blew the crystal loose. I'm trying to figure out two things:
--how to remove the bezel (it's a black plastic ring, not the earlier metal ring that is held with circle spring)
--what is best way to reinstall the crystal in the bezel.
Any help appreciated. I looked at the LonIsland Indicator site and didn't see info specific to this plastic bezel removal.
eKretz
Active member
You can do a makeshift crystal press with a mill vise and some scrap nylon pretty easily. Google crystal press and you'll get the idea pretty quick. I can't help with the removal of the bezel, haven't had to take mine apart yet.
specfab
Active member
Thanks for the note. I haven't figured out a risk-free way to get the bezel off yet either. Maybe some heat and prying, but I just don't have the wherewithal right now to devote "quality time" to this. Might contact Starrett to see if they have suggestions that don't include vacuuming my wallet.
