stephen thomas
- Jun 3, 2001
I sometimes make brazed tools (shaper wing cutters, e.g.) with stellite tips; so am familiar with the material and prefer using it (building tools with it) over carbide. But it occurred to me that i can't remember if i've used stellite on plywood edges. The "party line" from one source, which is repeated by every other mention of stellite online, is that it is "not good on glue lines". I can't really remember. Seems like if it was not good, i'd have noticed. But again, maybe never applied it specifically to ply.
Today i made a set of cutters to go in a shaper tool body. to cut a 1-3/4" dia specifically on plywood.
Naturallly i used carbide. One of the cutters cracked after the silver solder cooled, i decided to carry on anyway. No different than a multi-piece edge. Literally.
Then they both showed cracking after roughing out the blanks.
Since i wanted to prove the process to myself (that the method of radius grinding would work) i pressed on.
The cutters would probably get this shortish job done, OTOH I'm probably not going to run them.
I've made brazed carbide tools & sets in the past too, never had a problem, but never quite this wide, either.
One thing that occurred to me is that the carbide blanks were "unknown" and part of an auction box lot. They were probably C6 instead of the C2 i normally use.
So, need to make the cutters again on Monday.
Can go to my stash of C2, and take some precautions in fabbing that i neglected in a hurry on these.
But really, i'd rather use stellite.
Again, the tool will be used to round over (not full bullnose) the edges of 1-1/16" thick micro-lam plywood.
Anyone with experience think stellite would "easily" run 40 ft?
Blanks shown are a little over 2" wide, the radius is 7/8" or 1-3/4" dia.
Multiple cracks in carbide are easily visible. click on photo and then use magnifier /+ icon if not.
