Strange Retaining Ring on Motor Shaft - Unable to remove bearing
stickyboomerang
Mar 9, 2023
Hello--
I am trying to replace a bearing on a pump motor and I cannot figure out how to remove this bearing. There is a weird retaining ring or washer that is roughly the size of the inner race of the bearing and is preventing me from pulling the bearing off (see photos). The ring does not have any features that could be used to remove it so it seems like it might just be a washer. There is a quite a bit of corrosion on the shaft so I was thinking it might just rusted in place. I have been applying naval jelly to try to break it loose but still cannot get it to budge.
Is anyone familiar with this type of bearing retainer? Any ideas or suggestions for removal? I can't use a torch because there is a plastic molded fan on the rotor right behind the bearing and don't want to risk melting it.
Motor info:
Emerson Cat. No. 9352-6107
Model T55MWCFR-1288
DDoug
Oct 18, 2005
NW Pa
Hello--
Motor info:
Model T55MWCFR-1288
How are you trying to remove this ?
stickyboomerang
Mar 9, 2023
I'm pretty sure the bearing would be assembled on the shaft from the RH side in this photo. So it seems like it has to come back off this way?
Gearclash
Feb 1, 2017
Time to destroy the bearing. Pop the seal out. Then remove the ball separator. Push the balls all to one side of the race grooves. The outer race should be able to fall toward the inner race where the balls are missing; this will allow the balls to be removed from the groove. Once the balls are out the outer race will come right off. Then the inner race is accessible for heating or grinding. I prefer just to cut the inner race with a cut off wheel, but that may be hard to do here. If there is a retainer there it will be easier to fight with the outer race gone.
DrHook
Oct 8, 2013
Pierre
Lay a straight edge across the bearing and see if the inner race is truly higher than the outer shell. If not, there is nothing there, according to pics of that bearing on the 'net. As Doug said, cut it apart with a cutoff wheel, or carefully with a plasma or oxy-acetylene torch, if you have the ability. Piece o cake!:D
sfriedberg
Oct 14, 2010
Oregon, USA
It wasn't until the photo in post #8 that I realized what "that crap on the shaft" is. It's what's left of the shaft! Looks like over 10% of the diameter of the shaft has corroded/eroded away.
Let me ask what you intend to do if you get the bearing off. You probably will not be able to remove/replace the shaft from the motor rotor. (Did this thing sit underwater for years or something?) Are you planning to metalize the shaft and turn it back to size again? That seems like a massive amount to build up by metal spray, and I can't imagine brazing or welding on material is going to make the rotor very happy (or the shaft very straight).
MrWhoopee
Nov 8, 2017
^^^^This^^^^^
What was on the end and how loose was it?
This is looking like a complete shaft replacement, if that is even possible.
guythatbrews
Dec 14, 2017
MO, USA
Yeah looks like my hot tub pump shaft. Impeller screws on the end. My guess the seal failed and corroded the shaft. A lot. The impeller has a long hub on it that covers the shaft but water can still get in and f things up.
I turned down the corroded part and sleeved it with a piece of SS. It's been running that way for years.
Pissed me off at the time they used plain carbon steel for the shaft. But I guess they saved a dollar or two.
Good idea. Do this. Once you get the outer race off you can just flat grind the inner race all the way through with an angle grinder. If you hit the fan or the shaft a bit it will still work.
GregSY
Jan 1, 2005
Houston
I don't see any retaining ring...just the inner race. I was expecting to see a 'wedding band' type of retainer, as used often on automotive axle bearings. But that isn't one.
As others have said, whatever that rotor is from, it needs to be lowered into the scrap bin. It looks far too cruddy and far too small to warrant fixing.
stickyboomerang
Mar 9, 2023
I was able to get the bearing off using the method Gearclash described.
This is from a hot tub jet pump. Seal failed and the shaft corroded just like guythatbrews guessed.'
Thanks everyone for the input!
