I have the double belt Doucet triangular sander which is the lower cost version of the Kuhlmeyer and KBM. It's a good machine, made in Canada, mines got a 10' table and I use it for both weld grinding, surface prep and finishing stainless. Doucet also makes a line of less expensive traditional stroke sanders that I believe have the option for a double belt pulley. You can obviously get by running through the grit sequence with a single belt, but it's nice to easily switch on the fly if you need to redress an area with the coarser belt. Sometimes it's hard to tell until you're making passes with the finer grit.
Volpato is an Italian company that's worth a look. They make good sanders, guessing a little more expensive than the Waters you quoted.
