Stuck port on air compressor / sealing leak
jml74
Oct 18, 2017
I've got a Champion 5hp 80gal compressor that's a few years old that's never held air all that well, but I just lived with it. I finally decided to look into it and found a leak around the exhaust port; I swapped the ports before I started to use it due to clearance issues and apparently didn't get that one tight enough. (By port I mean the large 2"+ plug, not the smaller outlet in the center of it that the valve attaches to.) Anyway, it is of course now frozen completely solid and I'm worried about damaging something if I keep trying to force it. I've soaked it in PB Blaster without luck, but I haven't tried heat yet. Is it worth it to try heat? If I just leave it alone is there something I could put around the outside at the joint that will seal the leak?
jerholz
Sep 24, 2015
Dallas, Tx
I've got essentially the same compressor that had the same leak. After trying heat and a pipe wrench with a 6 foot cheater (I bent the handle on the pipe wrench), I ended up cutting and grinding the fitting out. Mine was a weird straight pipe thread with an O ring seal. The local compressor guy told me to just replace it with a standard 2 inch pipe fitting with some sealant. It's been leak free so far.
jml74
Oct 18, 2017
Yeah, I didn't have a pipe big enough for a cheater, but using the largest pipe wrench I had I was lifting the whole thing off of the ground. I may just continue to live with it for now, but it's good to know there are alternatives. It's a slow leak, more of an annoyance that I know it's happening than anything else.
