Chips Everywhere
- Apr 29, 2021
Having little experience grinding, but having the need to service dovetails on a cross slide. The thought of mounting a wheel on a BP to address the dovetails popped up. Can this be done successfully?
These are the drawback that come to mind:
-not enough rpm for the wheel
-table moves too slow, causing the wheel to excessively rub on the part
-Exposing the mill to grit
-Potentially having the part bow from the table sagging under its own weight as it travels.
I’m going to send the cross slide out to be ground, I’m just curious if one can get good results using a mill.
