Synchronize spindle to drive for BT30 clamp release.
marsheng
Sep 13, 2020
I'm reassembling my spindle drive and I have to get them correctly aligned.
In my ToolChange macro I have
M05; SPINDLE STOP
G17 G91 G80 G0; DEM G STATION
M19; SPINDLE ORIENTATION
M86; ENTER ATC MODE
So I presume I enter M19 in MDI mode (hopefully the drive moves to the correct position) and then I match the spindle to drive.
DavidScott
Jul 11, 2012
Washington
It's always been a parameter change to make the spindle orient correctly for a tool change in my experience, either at the control or the spindle drive.
marsheng
Sep 13, 2020
Here is my full Tool change program.
Is the M00 the release spindle in G-Code?
09021(MANUAL TOOL CHANGE MACRO)
IF[#1015 EQ 1] GOTO 50; CHECK MACHINE LOCK / Z AXIS LOCK
#1100=1; CHECK M86 COMMAND FORM 09020 SIGNAL
#101 = #4001; MEMORY G CODE
#102 = #4002; MEMORY G CODE
#103 = #4003; MEMORY G CODE
M05; SPINDLE STOP
M86; ENTER ATC MODE
M07; AIR BLOW
G30 Z0.0; Z AXIS RETURN SECOND POINT
M00; PROGRAM STOP
M07; AIR BLOW
G28 Z0.0; RETURN REF
G#101 G#102 G#103; SET G CODE
#1100 = 0; CANCEL M86 COMMAND FROM 09020 SIGNAL
M87; FINISH TOOL CHANGE
N50 # 3000 = 2 (MACHINE LOCK / Z AXIZ LOCK) ;ALAM MESSAGE
M99;
marsheng
Sep 13, 2020
It can't be M00 as the auto tool change does not have a M00.
09020(TOOL CHANGE MACRO)
IF[#20 EQ#0 G] GOTO 40; NO T CODE
#106 = BIN[#1032]; SPINDLE TOOL NO. READ
IF[#106 EQ #20] GOTO 30; IF SPINDLE TOOL NO. EQUIT MAG. NO
M05; SPINDLE STOP
M86; ENTER ATC MODE
M07; AIR BLOW
T#20; SEARCH TOOL
M07; AIR BLOW
N30 M99; RETURN MAIN PROGRAM
N40 # 3000 = 1 (M06-NO-T-CODE); ALARM MESSAGE
M99;
M99;
