QUOTE'
" Right now I have it so that the cylinders bottom out at full stroke at the required lift height, which levels the unit perfectly. they just don't bottom out at the same time."
That indicates that the load is not symmetrical. If it were the rams would rise at the same speed.
The idea of double acting cylinders, feed the downstream cylinders from the rod end of the cylinder won't work. That would be an "intensifier. ie., increased pressure from the smaller area, but reduced flow, and where do you get the additional fluid hen you have extended the first cylinder?
A hydraulic loader with 2 cylinders WILL have the same pressure on both cylinders, I don't care how much weight is on one side of the bucket or the other. Guages on both cylinders will read the same, as they are plumbed in parallel, teed to feed both cylinders. If one ram has leaky cups, both will drop in synch. If your valves close off both advance and retract, then, no, the cylinders will not lose pressure, as there is no place for the leakage past the cups to go
My company lifted 500 ton turbo generators with centralized Enerpac, and they lifted evenly. BUT, the 4 corners were uniform in weight.
"You then would use 4 pilot operated check valves to resynch the single acting cylinder at the top of the stroke. I.e. one cylinder is leading the other three, it hits the end of its stroke, the pressure rises in the line, then the check valve opens to allow the fluid to drain back to tank until the other three meet the end of their stroke."
" it hits the end of its stroke, the pressure rises in the line, then the check valve opens to allow the fluid to drain back to tank ."
That is impossible. The pressure cannot rise in that line, if they are all in parallel. The same pressure on all 4. IF one ram were smaller area, it would lift quicker, but the pressure on all 4 will be the same, and in an hydraulic system, you do not dump fluid from one cylinder to allow the others to catch up. If you DID have a valve open on a common rail system, as you are describing, if your "check valve" opened, you would lose pressure to all you cylinders. One is faster than the others, and I think you are referring to something called, properly, a "buffer valve", if it opens, system pressure falls off, you quit lifting, simply dump back to the reservoir.
JWaldo,
Also known as a "Walking Beam" conveyor. We had them to move 35 ton coils into the Pickle Line infeed.Couple hundred year old idea. Nothing new under the Sun, though we might just dream up what we never saw. Re-invent the wheel.
"There isn't any cheap and simple way to synchronize four hydraulic cylinders.'
Bullshit! 4 identical cylinders ARE self synchronizing. Even IF one is dumping fluid past the cup and all over the deck, all 4 will have the same pressure in them, and I have had a LOT of "professionally rebuilt" AND new Enerpac rams, 100 ton, leak like hell on first use trying to lift the corner of a 400 ton weight, not capacity, EOT. Carry that sumbitch down 60 feet, get another and hope that one will see the job through.
Hydraulic lifting devices were much better when there was competition. Now, I think Enerpac has gobbled them all up, take it or leave it.
I have been involved in hydraulics since 1962. School, even. And we have people who want to conjure up mechanical contraptions, OR tell you it will cost 5 figures to lift half a ton 3 inches. Airbags, 500 each? Can't get the air in each one the same pressure? One corner lifts quicker? Back to Square One.
Scissors like mechanical device? 500 pounds? How do you lift it high enough to get a 1 piece lifter under it? 2 devices, split, how do you lift each side to install? Pinch bar? Then a chain or something to drive them both. Synchronized? Fat chance.
I have said my piece. Your original idea is the best solution.
George
