T plus control programming radial grease groove in OD.
Tplal1
Jan 27, 2018
Looking for some help programming a radial grease groove.
I think i have most of the bugs worked out but now i am getting a 638 Illegal designated tool width alarm.
I am using a .078 wide grooving tool (full radius nose)
in tool data 2 I have NR in at .078 and the cut-ang column also at .078
does that sound correct?
Thanks for your time!
also i forgot in the line of code the width area to put the groove width in is highlighted.
is this normal? I will try to post a pic to make it clear as to what i am dealing with.
Thanks again!
Philabuster
Jul 12, 2006
Tempe, AZ
Thanks again!
Tool width alarm usually means the groove width needs to be wider than the tool width for the type of groove you are making. Groove 0 can machine a groove the same width as the insert. This would be a simple plunge in and pull out motion. The Z dimensions on groove 0 are based on the left side of the groove.
Please post a pic of the program and also a sketch of your part.
Philabuster
Jul 12, 2006
Tempe, AZ
I can barely make out one picture. Can you post higher resolution pics? The print is too small to read.
One thing I did notice was you have your tool nose radius the same as the groove tool width. Tool nose radius needs to be 1/2 of the tool width.
Tplal1
Jan 27, 2018
Phil,
that was one of my attempts to get it to work.
i eventually got it running.
i will post a pic of the program that worked. its not perfect but was satisfactory for a grease groove :)
Thanks for all you help!!!!!!!!!!!
Philabuster
Jul 12, 2006
Tempe, AZ
Phil,
Cool. Glad you got it working. Pictures are much clearer.
Please post more questions when you get stuck on something. We are here to help. :cheers:
