novation1
- Apr 3, 2017
- Columbia Station, Ohio USA
Hi All,
Same machine as no video. I got a FX884 board and installed it today. The control came back to life. Problem now is there is a drive alarm problem that is keeping it from running. On the control the alarms are 13, 14 and 20. Before the monitor quit working it didn't have a drive alarm. I'm not sure now if the problem is due to this new board being from a machine with a different drive set up or some other thing that happened at the same time that the monitor went out. I put all the parameters back in the control. and they all went in ok. Every thing seems to work that can with the E-Stop alarm on. I'm guessing that it is set due to the drive alarm. The error code on the drive is 37 on both Z and X. I have a maintenance manual I downloaded from MEAU website for the drive. It seem to be saying that the error 37 is due to a incorrect initialization string sent from the control. At least that's what I got from reading it. Are there some address that are available through the diagnostic screen to change the info in the specific memory for that string. And what would the correct data be. I'm going to call MEAU tomorrow and see if they will even talk to me about this issue. I called them right after I got this machine for some information on the T2 control and while they tried to be helpful it didn't seem as thought anyone was still there that knew anything about the control.
Hopefully someone here has had this same problem and can shed a light on the solution. Making some headway, at least the control is mostly functional.
Bob
Bob
