T32-B can you program a drill to do another process as a boring bar
M K
Feb 7, 2018
Hi
I have a Hyundai QT15n with Mazatrol T32-B
There has been a few times recently when I’ve drilled a hole using a big 35mm u drill then had to bore it out to 100mm and it would be great if I could bore it out with the U drill to save taking up another holder with a boring bar
On these older controls can you program 2 separate operations using the same tool number somehow like you can on newer machines ?
So have op1, drill, tool 1
And then op2, bore, tool 1
Thanks
Marc
gmc1724
Oct 24, 2013
United Kingdom
Hi
Thanks
Marc
Does the T32B allow you to assign a letter after the tool no as the T32 does? If so just call up T1 as a drill and T1B as a boring bar, don't forget to add it to the tool data page and set both offsets and tool geometry correctly.
Philabuster
Jul 12, 2006
Tempe, AZ
On my older T2 control, I cannot assign one station to have multiple functions. So what I do is probe the U-drill as a boring bar and describe it as such.
In order to drill a hole, I use a MNP process and bring the X to the drill nominal diameter (say 1.0") and then G1 Z-into the part with a feed rate, then G0 back out on Z. Then next process is a BAR IN with the same U-drill for roughing.
M K
Feb 7, 2018
Thanks for the reply guys,
I had a proper look today and YES it is possible, you have to assign a letter prefix to the tool and then add that tool prefix to the tool table
So for example I used tool 2,
In my tool table I only had tool 2 described as a drill, But I didn’t realise you can add more tools to the tool table! So I then added a tool 2A and described it as a boring bar
Whenever you add another tool it then adds another tool offset column so I can touch off tool 2 at x0, z0 as you would a normal drill and then I can touch off the same tool but designated as tool 2A as if it were a normal boring bar
When I write the program I add a drill op using tool 2 then when I add the bar in op I call tool 2A
I really should have fully gone back over the manual before asking in here as all the info I needed was in there
Really helps out when your pushed for tool pockets as mine is only an 8 tool turret
Thanks
Marc
