T32B threading queries
M K
Feb 7, 2018
When I’m OD threading on my QT15n T32B the first cut seems to be huge and just tears into it!
Even if I put maximum no of cuts in, the first cut is too deep and so is the last 1 or 2?
I have changed the parameter for the final depth of cut but it doesn’t seem to make a difference
Anybody experience this? Of have any ideas?
Thanks
Marc
cnctoolcat
Sep 18, 2006
Abingdon, VA
In the T2 threading unit there is a "first DOC" (or similar) value you enter. Does your T32B unit have this? If so, then it's easy to set the first pass depth.
Check your User Parameters --- there may be one for first pass DOC, or minimum DOC when threading.
I do remember a "minimum DOC when threading" parameter, and a "final/skim cut DOC" parameter...
ToolCat
M K
Feb 7, 2018
Hi Toolcat
There is a final depth of cut parameter but not a first cut depth one,
You just set the lead, and it will auto set the thread height and depth of cut which I can change manually but doesn’t seem to affect first depth of cut
Thanks
Marc
Gobo
Jun 4, 2013
Oregon, USA
You can use threading cycle 1 ( constant depth of thread) might not be the perfect solution, but it will keep the first pass from being excessively deep. For ultimate control, use a Mazatrol manual threading cycle using G32.
