Sharpness10
- May 18, 2023
Hello, New to these forums as registered, but I cant find the information I am looking for for the life of me. So if you can, please help me out. I am currently planning to build a completely DIY CNC lathe with tool turrets, tool changers, cooling, the works. But since it is DIY, I am on a budget. I want this lathe to be able to accurately cut threads, so I need some sort of spindle motor that knows its position. Going from here I have a question. What motor would you suggest to use ( Knowing that the chuck is 100 mm in diameter and the motor should be around 1 kW, maybe a little less ) ? I know Servo motors can be used for this with great accuracy and success, but they are quite expensive. I have seen people use regular motors with induction sensors on the shaft to count steps, but I am not sure what kind of motor do they use and what kind of control, would be great if someone could explain in greater detail. I hope someone can help with picking the correct motor without overspending !
