Hi All,
I purchased a 1985 Takisawa TP-3 Lathe, FANUC 3T, no extras or addons, knowing that it had some issues. One alarm pops up on the X axis. The machine will home fine, but after moving the axis it will not go home again without an over travel alarm. But the limit switches are not even being touched. Until I turn off and on the machine I cannot reference return. Also have to do P + Cancel on startup. I decided to check the pulse coder on the x axis. The machine is coated in oil, so I thought something might be up. Long story short, it looked good. Someone had been in there before though.
Put everything together again and for the first time the machine ran a program with no errors. Not even an axis error on start up. Homing was no problem. Later on my bench I see a little piece of electronics. Exhibit A. NEC diode (I believe) Then checked the pulse coder PCB. Exhibit B. Position C1 At the top you can see something obviously broke off. My quandary is...the machine is now running...but its technically broke...do I fix it? I'm not sure of the function of that particular piece of the PCB. My only concern is that could it lead to a crash? My experience with alarms is that the machine stops. It really seems that either the diode(?) was bad or broken somehow and shorting out. Why else would the alarms stop.
Any thoughts? Thank you for your help.
