Brian
- Jul 20, 2002
- Phoenix, AZ USA
Fadal made a special bracket that you bolt up to a Tapmatic head that clocks it in and out of the tool changer. That's your fastest way to tap. Second is the tension and compression unit with Bilz style quick change holders, if you use the clutch versions, you can tap to the bottom of a blind hole and not worry about breaking the tap if it hits the bottom. Thread milling on anything over about a 1/4" hole is good, but if you use a single form thread mill you have to circle a lot of times to get to thread depth. If you use multi tooth cutters they are pitch specific, so a 16 pitch will only do 16 pitch threads and so on.
