Maverick302
- Dec 24, 2018
Hello Brian,
Extension, Compression tapping tools are available that have a Freewheeling zone. Typically and in its simplest form, its an axial slot in the bore that the tapping tool runs in, with a drive pin engaged in the slot. The Freewheel feature is an Annular groove that the axial slot crosses. To operate:
1. the Z axis is stopped short of the full depth to be tapped and a dwell programmed. During this dwell the tap continues to feed towards the bottom of the hole until the drive pin finds the annular groove. In this position, the spindle can rotate but the tap won't be rotating and therefore, no further feed of the tap occurs.
2. the spindle rotation direction is reversed and the Z axis starts to feed back towards the Z Start Point for the tapping operation. As the Z axis moves, the drive pin engages in the axial slot on the opposite side of the annular groove and starts to feed out of the tapped hole.
With this type of Tapping Tool, very accurate tapping depths can be achieved and tapping close to the bottom of a blind hole is consistently achievable.
Regards,
Bill
This actually sounds like the perfect solution. Do you happen to have a brand or link you could share?
