Telescoping Leadscrew for what lathe???
rimcanyon
Sep 28, 2002
Salinas, CA USA
I'd like to identify the lathe this telescoping lead screw fits. It is 32.5" long and is threaded 15/16"-5. It has two nuts on it, but I believe the nut that came with it is the one on the inside. The other nut has a tag that says 80164 & R92268. I suspect 80164 is the serial number of the lathe it was ordered for. It came with a large lot of machine parts I bought from GE at least 20 years ago. I know that 80164 is not a Monarch lathe serial number, because Monarch serial numbers end in the 50,000's, but that tag may be a misnomer. It is made very much like a Monarch telescoping leadscrew, with a threaded end for a thrust block and a keyway at the telescoping end.
jlegge
Oct 7, 2004
Grayslake, IL
Contact Monarch Lathe LP, they might be the best source to ID the leadscrew and what it was used on.
Also, Monarch Part number were 5 digits. The 80,xxxx number would have been sometime in the 1970-80s timeframe.
