Ox
- Aug 27, 2002
- West Unity, Ohio
Along the lines of what I had typed for my first reply, but then backed out b/c it was not per the Swiss theme asked, but:
You mentioned rolling threads on a Swiss.
In what regards are you rolling threads on a Swiss?
You must mean a Fette head?
That's purty bulky up in there, but ...
I don't know that I've heard of that done very often...
However, the pattern in G1 could possibly be done in a Fette head, since it appears to me that a spiraling effect would not be a problem? I just don't see a rolling die (in "S") ever tracking good enough to be used in G2 or G3. But for use on G1 - maybe. You would need someone like Sossner to make the rolls, not Fette.
I would think that having the pattern split up between 3 different rolls (like a LH and RH knurl) it could possibly be dooable. BUT, I would NOT recommend planning on it running on a common bar size. I think that you would want to plan on peeling the bar down a smidge as you feed out, to get it to track in a LH, RH, or possibly straight pattern.
You would need a wide tool surface to handle high feedrate w/o leaving big swirlies in the bar surface. So - likely a HSS stick tool with a slight feed in and out rad. Then feed through the Fette that would be mounted in your sub-spindle so that your bar feeds right out the back of the machine.
You would want to stop the sindle and pull the Sub back enough to pop open the head for removal porpoises. Manually pull the bar out the back and manually reset the head.
Now, for the likes of G2 and G3, I envision a motorized bar marker with 3 or 4 concave stencile dies that you just pass the bar through. Again - this would likely be a Sossner tool. I have no clue if the machine is real or just in my imagination. They doo make single roll bar marker machines for imparting company logo, or whatnot all along the bar before it is made into parts. But what I envision here would be a much more involved machine than that.
G4 looks like a lazer deal.
H1 looks like you just need to toss it in the cement mixer with a few others.
Think Snow Eh!
Ox
Think Snow Eh!
Ox
