ballen
- Sep 25, 2011
- Garbsen, Germany
Hi Buck,
I agree with this too, which is why I am planning to follow Richard's advice and NOT grind the table top. But I will stone it!
Yes, I'll pay particular attention to the edges and corners. But the vise sits a few mm inside the boundary of the pad.
It looks to me as if neither the back or side edge of the chuck have ever been ground true. Both have gray paint on them, visible in the photos above. Is it right that both the edge of the chuck and the edge of the bump rail should be kissed/dusted in this?
Buck, I have an unrelated question for you or another J&S 540 owner. With the table off, I wanted to check that the lubrication of the ways was working well. So I turned on the hydraulic pump. But there was no lubrication coming from the way oilers. Is this to be expected? Will the table lubrication only flow if I turn on the hydraulic feed? Is it safe to turn on the hydraulic feed without the table attached on top? The hydraulic rams will move to the end of the travel, but will that damage them if they are not connected to the table/reversing valve?
Cheers,
Bruce
Because the geometry of the machine is very close to perfect....
I agree to that, the blue in shows enough hits IMHO to be filled with a coat of oil or grease and so not be a problem for a good number of years .. and then a next chuck top grind and so another under cleaning may be due.
I normally figure 8 ore straight (fine side) hone the chuck sides for bugs and bruises and with an inward hone stroke hone a small bevel to all the edges, with taking most care to the pad facing edge corners with the stroke gong away from pad direction. hone direction important to remove any to not make a burr.
.. the back bump rail is ground in place with a dish edge wheel to make square so I indicate square the chuck front edge because you can't grind that rail in place.
Cheers,
Bruce
