And a secondary function is tool grinding, with simple fixtures for lathe bits, chisels etc. and more complex ones for things like end mills.Likely you should tell what products you commonly make and then the guys here might focus on how a SG can help.
I think they are no more or less safe/dangerous than a mill or a lathe.
Making flat and true is the most common function.
A Harig 6x12 is easy to transport or move and a very decent grinder capable of a lot. (done it with a mini-van)
Have owned many more than one so some bias is fully admitted.
Next step up in my book is a B&S 6x18 manual. More accurate for high volume work. Not so easy to take home or move.
Dust collector? Small shop vac but a good sized bathroom fan in a cardboard box with a hose and filter is much quieter.
Coolant? As said above but I need real coolant so cut off 55 gallon drum and sump pump running full on.
Coolant containment? Cardboard and duct tape, handful of plexiglass pieces, roof rubber and magnets. Serious wet and you will want a sheet metal tray and ends.
There are low cost surface grinders of this style. https://www.amazon.com/Grizzly-G596...ocphy=9017065&hvtargid=pla-978862644136&psc=1
Let's just say not so good and I'd stay far away from this design.
Dangerous? My bench grinders have bitten me, grabbed parts and blown up more.
Bob
Nov 17, 2021 · After careful consideration, Tormach has decided to discontinue the manufacture and sale of our PSG 612 Surface Grinder (PN 32789). The standard warranty terms will be honored for all units shipped to date.I have a 3yr old Tormach here at work, and it is a POS after maybe 10 hrs run time. Buy a used REAL machine, and learn how to run it.
Notice
