danasummers1
- Jun 18, 2022
Does anyone know the thread size for the WEN 2305-KC Keyless Rotary Tool Chuck and where I can purchase a die to cut the same size threads on round stock?
Larry if I use the 5/16-.30 die what diameter round stock metal solid tubing would I used to cut the threads?It was not very difficult to find your answer on the Amazon Q&A section for the Wen chuck.
"Question:
Will this fit Dremel tool?
Answer:
NO IT WILL NOT FIT DREMEL OR ANY OTHER TOOLS UNLESS THEY HAVE AN M8 x 0.85mm Thread
I have been searching for hours, until I found that the WEN 2305/2307 Collet thread is an M8 x 0.85mm (30 threads per in) -"
That is very close to 5/16-30. Victor has the die for $11.50.
5/16-30 Special Pitch Round Die, 1" Outside Diameter - High Speed Steel
5/16-30 Special Pitch Round Die, 1" Outside Diameter - High Speed Steelwww.victornet.com
Larry
How is 30 threads per inch derived from M8 x 0.85mm? Thanks
Good luck finding that solid tubing in 5/16. Or in any other size.Larry if I use the 5/16-.30 die what diameter round stock metal solid tubing would I used to cut the threads?
Hmm. Good point. Probably not, as 5/16-30 is not a standard size. So, we are back to M8x0.85, which is also not so common, judging by what McMaster carries. So it's a custom job either way, so might as well make it exactly M8x0.85, perhaps starting with 5/16" (7.94mm) stock, perhaps oversize.I wonder if Joe Gwinn, whose location is stated as Boston, MA area, really has a local hardware store that stocks 5/16-30 nuts and bolts.
No lathe, no chance. The die would be so expensive that it would be cheaper to cannibalize a Wen tool for the shaft.Hmm. Good point. Probably not, as 5/16-30 is not a standard size. So, we are back to M8x0.85, which is also not so common, judging by what McMaster carries. So it's a custom job either way, so might as well make it exactly M8x0.85, perhaps starting with 5/16" (7.94mm) stock, perhaps oversize.
But what do 5/16-40 taps and dies have to do with this thread?Victor Machine has 5/16-40 HSS taps for $12 - model 5/16-40 HSS Special Tap, 0307-0022.
https://www.victornet.com/subdepartments/Special-Pitch-Taps-up-to-1/2-inch/1260.html
Dies too:
https://www.victornet.com/detail/RD-5/16-40-B.html
Real close to M8-0.85, which is much discussed.But what do 5/16-40 taps and dies have to do with this thread?
Larry
No, not nearly as close as 5/16-30 (M7.94 x .847), which was discussed thoroughly above.Real close to M8-0.85, which is much discussed.
Victor has metric taps and dises, but not exactly M8x0.85, but I'd get a quote for sure.
Dear expert friends... my months of off and on sifting causing 100s of MBs of saved webpages, diagrams and videos has brought me here...and this excellent comment with url by you!It was not very difficult to find your answer on the Amazon Q&A section for the Wen chuck.
"Question:
Answer:
Larry
Notice
