Threading noob
FrankieB
Jun 28, 2019
Hello all, i am single point ID threading mild steel. I am having some chatter issue on the last 2-3 passes. Any suggestion on rpm and doc to help correct this.
Machine sl30
Insert is a lay down style sumitomo on a 1.250 bar
Thank you
Edit: current rpm is 400, doc is 0.005 finish doc is 0.002 radially
maguilera
Jan 4, 2022
What thread pitch and diameter? Also would be great if you share the threading section of the program.
Cheers.
FrankieB
Jun 28, 2019
Cheers.
Thanks for the reply but i got it figured out. I beeded to increase the first pass doc so the rest of the passes would also increase. I also increased the final pass doc.
