First and foremost, define your thread properly so people know what you're talking about. There is no such thing as a 16mm NPT, and I think you're using "depth" to mean the length of the thread? When talking about a thread, most people assume "depth" to mean the height of threadform, analogous to "depth of cut" - in the case of 14tpi NPT this is around 1.45mm...
14tpi leaves two options for NPT - 1/2" or 3/4", and 16mm long suggests 1/2", as it is halfway between L2 (13.556mm) and L4 (19.85mm) of that thread.*
If you'll forgive me for making assumptions, your apparent lack of knowledge of these threads leads me to ask if you know that these are gauged threads, and if you have gauges for them? It's
possible to make an NPT by measuring pitch diameter at specific locations, but it's quite difficult...
Secondly, make sure you're using the right insert. ER14tpi is not an insert designation. Are you cutting the NPS and the NPT with the same insert? You should not be. Full profile NPT inserts have the taper angle built in, so an NPT insert will not crest an NPS properly, and vice versa. The deviation is likely very small at 14tpi, but it remains true all the same.
Thirdly, make sure your rough turning pass is leaving very minimal material over the thread major. Just enough for the insert to crest, but not more. Like around 0.2mm on diameter over the thread major - this is tricky to get right on an NPT because of the taper.
Lastly, years ago I did a job that had huge quantity of NPT threads cut on 316 pipe, from 1/2" to 4". I started out with Vardex inserts (I forget the grade and geometry, but it was definitely appropriate for the material) and had the exact problem you are having - edge built up followed by the point of the insert breaking off. I switched to Sandvik's 266 system and got quite literally
10x more parts per edge, changing nothing else. That was the job that made me switch wholesale to Sandvik for threading and ditch everything else.
*Edit, I missed your last post stating 3/4", sorry
If you'll forgive me for making assumptions, your apparent lack of knowledge of these threads leads me to ask if you know that these are gauged threads, and if you have gauges for them? It's possible to make an NPT by measuring pitch diameter at specific locations, but it's quite difficult...
Lastly, years ago I did a job that had huge quantity of NPT threads cut on 316 pipe, from 1/2" to 4". I started out with Vardex inserts (I forget the grade and geometry, but it was definitely appropriate for the material) and had the exact problem you are having - edge built up followed by the point of the insert breaking off. I switched to Sandvik's 266 system and got quite literally 10x more parts per edge, changing nothing else. That was the job that made me switch wholesale to Sandvik for threading and ditch everything else.
*Edit, I missed your last post stating 3/4", sorry about that.
Sorry for the problems you had to face . actually i am new and will take care next time while asking question as in to put in proper details. however i thank you very much for guiding me to use sandvik for threading. i will contact the sandvik dealer for help. really appreciate your post and suggestion. thanks a lot
